It is currently Sat Jul 26, 2025 5:09 pm
PostPosted: Mon Jun 13, 2005 3:15 am
Is it a good idea to put Loc-Tite or something like that on the neck bolts? The reason I ask is, the first guitar I made, after about 3 months, started sounding kind of funky. Come to find out, the neck bolts had backed out some. This being my first, I don't know whether I didn't get them tight enough for fear of cracking the neck or whether the vibrations over time caused them to loosen.
PostPosted: Mon Jun 13, 2005 3:18 am
I don't use loctite on mine but I snug them pretty good using a screwdriver type hex wrench. You wouldn't want to torque them with any leverage.
PostPosted: Mon Jun 13, 2005 3:30 am
I wick in a drop of CA into the threads after Ive turned them all the way into the heel. I use the anchor style bolts that thread into the end grain. So far, after 3 years, none have loosened.
PostPosted: Mon Jun 13, 2005 3:57 am
Jimmie, are you talking about the bolt itself backing out or the threaded insert? I assumed you meant the bolt. I don't use threaded inserts, I use barrel nuts or cross dowels on my necks.
PostPosted: Mon Jun 13, 2005 5:30 am
John, I'm talking about the actual bolt itself. I wicked
CA into the insert afer it was screwed in. Actally the guitar that the bolts came loose on had the cross dowels.As I recall I think I didn't want to get them too tight for fear of cracking the neck. That may be the reason they backed out on me.
PostPosted: Mon Jun 13, 2005 7:39 am
I use Bellville washers to keep tension on the bolts. Supposed to keep the bolts from loosening.
PostPosted: Mon Jun 13, 2005 8:20 am
[QUOTE=JJ Donohue] I use Bellville washers to keep tension on the bolts. Supposed to keep the bolts from loosening.[/QUOTE]
If that is what you call those conical washers, yup I use em too.
PostPosted: Mon Jun 13, 2005 9:18 am
Does anyone have a source fo buying just the bellville washers? Does ACE or anyone like that carry them?
PostPosted: Mon Jun 13, 2005 1:55 pm
I got my washers through McMaster Carr. They were expensive, but worth it, Its better than the neck falling off.
I am sure you can hunt them down for less, but I order stuff from McMaster quite a bit so it was easy.
PostPosted: Mon Jun 13, 2005 2:20 pm
Do they also go by another Name. Over the last few years I'vre asked about them a stores and no one seems to know what I am talking about.
PostPosted: Mon Jun 13, 2005 2:55 pm
The also go by conical washer.
I think these might be the ones I got
Goto McMasterCarr.com
9294K59
There are many others, so that might be them, but it is a decent example.
PostPosted: Mon Jun 13, 2005 6:19 pm
I've used bellville washers (from MSC), but I'm not sure they are sufficient;
they are very small, and if they are bearing against wood on the inside
surface they could wear into the wood and lose their tensioning effect. I
think they need a hard washer underneath. Even with them I like to use a
drop of blue locktite. No reason you can't use both.Howard Klepper38517.1398148148
